Super Contributor II
Telnet
How many concurrent telnet connection can be initiated with Aruba  3000 controller ??
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
MVP
Re: Telnet
If you mean to a 3200
I mean simultaneous telnet connection to a 3200mx thats 5 concurrents... thats the top
Is that what you were asking?
Cheers
Carlos
Alternetworks Corp
Re: Telnet
I think that is what i was looking for...
Its mean 5 user can access and configure the 3200 controller via telnet at the same time.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
