Contributor I
Terminal Servers TSBroker Issue
I have 3 Server 2008 Terminal Servers running with NLB and using TS Session Manager to reconnect disconnected user sessions.  We are using HP thin clients connecting to an Aruba 135 access point with Aruba 3400 controller.  The thin clients connect and stay connected with to the Aruba access point.  When I launch Remote Desktop to the NLB TS Broker network address I connect and am forwarded to a 2008 terminal server.  We are running cluster operation mode in Unicast mode.  I log into my session and after several seconds I lose connection.  If I log directly into the terminal server without NLB I log into my session and never lose connection.
MCSE +Security,
IBM Certified Advanced Systems Administrator
