Terminators for AP318 unused ports?
We have a AP318 being tested with 2 X dual band OMNI antennas. In our setup, 5G0+2G0 connect to LCOM diplexor #1, 5G1+2G1 connect to LCOM diplexor #2 and a dual band omni antenna is connected to each diplexor.
Are 50ohm terminators required or recommended on the two unused5G radio ports 5G2 5G3?
Re: Terminators for AP318 unused ports?
Yes, terminating the unused ports is required.
Charlie Clemmer
Aruba Customer Engineering
Thanks for the clarification. Much appreciated. Well get some of these and retest.
It would be usefull to know generally the impact of having unterminated radio ports (what is the radio doing in this circumstance) and also whether there a way to turn off the usused ports perhaps.
