Hi everyone,
I have an issue that specific device keep connect to AP that is far away from itself. This issue occurs when I connect 5Ghz band SSID.
Please check the floor plan that shows the issue.
The controller model is 7205 and AP models are 215.
Those APs has one SSID for employee and it's not possible to use more than two profile.
The Wireless Lan card name is "ipTIME A2000UA" and it has "Realtek RTL8812AU" chip inside and supports abgn+ac, 2x2:2.
This is the issue.
The PCs are using this WLAN card to connect AP215 with 5Ghz Band and some of them connects to the AP that is placed in next door.
Also, it doesn't even connects to the AP that is above of its head.
I've checked this from the controller that shows this PC connected to next door AP.
So, those PCs are using 5Ghz with low signal and it's really slow.
The 2.4Ghz works fine but it's not mean to be use 2.4Ghz for this place.
But my Laptop and Smartphone connects to close APs and roamings well too. But this WLAN card is really weired.
Could it be only this device problem? or is it possbile that controller can handle this issue?
Please share if this is known issue or who has experienced.
Thank you.
