Frequent Contributor I
Time Based SSID Broadcast - Controller and Instant
Hi All
I was hoping there is a way to set a SSID to only broadcast at certain times.
On Controllers I know about the "Deny Time Range" option, however the SSID is still broadcasting during that time, is there a way to set profile to stop broadcasting all together during a specific time?
On iAP I see there options for Time Range (this under edit for the SSID and expanding Advanced) - however I am unfamiliar with the feature on iAP, setting a time range here will it only broadcast during that time or is it also a Deny like on the Controllers?
Re: Time Based SSID Broadcast - Controller and Instant
Hey, it will disable the SSID.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Awesome THX Zalion
Is there away to achieve the same on a Controller (3600 and 7210)?
MVP
you can deny connections but the SSID will still be visible.
You'll configure this under VAP - deny timer range.
Timer range is configured under Access Control - Timer range
or conf t, timer-range on the CLI.
Hope it helps
Borja
ACMX #567 //ACCP//CWNA//CWAP
