Frequent Contributor II
To generate Air Monitor report
I hv 3 AP 205 on the floor. This setup is working fine from last 2 year. but suddenly i user is complening low coverage and speed. There is no change in cabling/high voltage or wall.
So i hv decided to configure additional 1 AP as Air Monitor on the same floor, check the Air spectrum etc & share the report to customer.
Please guide me how can i prepare the AM report.
Thanks in advance...
Re: To generate Air Monitor report
You should check to see if any of those access points are in the rf health report.
Colin Joseph
Aruba Customer Engineering
