Tool for Sizing WLAN
  • 1.  Tool for Sizing WLAN
    Posted Jan 26, 2015 10:49 AM
    I saw in the aruba site, a tool to scale a WLAN according to the workspace. Does anyone know the link of this?
  • 2.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 11:02 AM
  • 3.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 11:08 AM
    Hi Tim,
    No, it's an option on the site where I entry office data such as size, number of users and it returns with the equipment they serve.
  • 4.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 11:14 AM
    This is the only other item that I know about:
    https://ase.arubanetworks.com/solutions/id/75
  • 5.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 11:23 AM
    you know it depend of many element
    1. Speed rate desired
    2. The environment
    3. the Area
    i don’t think that this kind of tools exist , but
    Generally commercial recommend
    1 AP for 20 users
    1 AP for 200 m²
    with your own experience you can create an EXEL script how do this work.
    And as said by capplari, VisuelRF is a very good tool, and you have to know that after the positioning it give you a bull of materiel how is very useful
  • 6.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 11:51 AM
    Hello
    If i were you, i woud use the first tool that  Tim  gave you.  Its more accurate, you just need the autocad plans or the plans on PDF.  There are also videos which tells you how to use it.
    The other is just too general, the one you want.   Because it will all depend on the envirment...
    The densitty and other things.   A good survey is not that easy.  If you want the wifi work properly you need to do a properly survey otherwise you would have trouble, in which if you do you wont have issues.
    Cheers
    Carlos
  • 7.  RE: Tool for Sizing WLAN
    Posted Jan 26, 2015 01:29 PM
    Hi, thank you all!
    I was talking about it:  http://cloud.arubanetworks.com/plan
    This was just to give an idea for resale, but I know that is not for a survey ..
    I'm studying more VisualRF
    Tks again!
