Frequent Contributor II
Traceroute and Ping
Hello, I have 2 questions:
1: is it normal to not be able to run proper traceroutes from a windows device connected through VIA? I only get time-outs when using traceroute, even though the connection works fine. Ping works fine as well.
2: is it normal that on the Aruba controller, a traceroute to an IP on the internet works fine, but a ping to that exact same IP times out?
Thanks!
Re: Traceroute and Ping
Your outbound firewall could be blocking it...
Thanks for the reply.
The firewall does not filter any outgoing traffic as far as I know. I will make sure by connecting my laptop to the same connection.
So it's not normal I guess? Ping to an internet IP works okay for you?
Ping does work for me with VIA to the internet, yes.
Ping from VIA to internet works me too. But how about Traceroute from VIA to internet?
And how about Ping from Controller to internet?
Ping from the controller to the internet should work, definitely.  Traceroute from VIA to the internet does work for me, as well.
Thank you. I'll try updating the controller to latest software, try on Windows 7 instead of Windows 8 and I'll do some more checking on firewalls etc.
It should work regardless of the software.  Who controls your internet firewall?
I do :)
Can you see if Ping traffic is being dropped by the firewall?  The controller is a layer 3 switch and should be able to ping with no problem.
