For doing a predictive survey using Visual RF, if I select an Access Point with internal antenna, when I drill down to the Xmit power for the radio, does the Xmit power refer to the EIRP or just the transmit power on the radio? Being the latter, does that mean I calculate the EIRP simply by determining the internal antenna gain value and adding it to the transmit power of the radio?
