Triggers for clients connected to an AP and a report question
Is there a way to create a trigger in which it willl send you an email notification if there are more than 30 users on one radio or something like this???
Is there a way to create a report in which it will tell you how many tickets were given or at least how many users were using the guest network on one month???
I bealive i can do this kind of report if i had Clearpass Guest... but let suppose i dont have and i just got the controller an a airwave
Carlos
Alternetworks Corp
Re: Triggers for clients connected to an AP and a report question
Yeah, it is the 'client count' trigger.  It alert when the user count for the AP goes above the threshold.
I think you can set it to alert for client count on a bssid as well, but generally I find the total clients on the AP itself is normally sufficient.
ACCP, ACCX #817, ACMP, ACMX #294
I agree with Michael on the triggers.
For reports in AirWave, you should start with the Client Session report.  That report, filtered on your guest roles and/or SSIDs, will give you a lot of information about your guest users.
Thanks!!!
But i dont remenber looking at that  on airwave 7.6.4 the client count... i saw it on airwave 7.7.1...
I ll have to check the airwave i leave the client which got 7.6.4 maybe i just missed it... but anyways thanks! alot!
Alternetworks Corp
