Trouble using RAP3 to extend wired network using wireless uplink option
I am trying to use my RAP3 as a network extension for my home. This is in place of running a wire to my printer up stairs. I have attached a diagram of my network because I'm sure I will slaughter the network description in this text. I have setup a "Backhaul" SSID on my Linksys router and I am connecting the RAP3 to that SSID using the Wireless uplink option.
When my PC is connected directly to the Linksys with Ethernet I can get to the RAP and Linksys, but not the printer.
When I connect the PC to the Test SSID on the RAP3 I can get to the RAP3 and printer, but not the Linksys.
And when I connect the PC to the switch I can get to the printer and RAP3 but not the Linksys.
As a side note I created a separate SSID on the RAP3 on a separate subnet 172.16.11.0 and when I connect to that I can get to everything. But I really only want to use 1 subnet. :)
Can anyone help me get all the devices communicating on the same subnet? I will provide a config also as an attachment.
Thanks!
Re: Trouble using RAP3 to extend wired network using wireless uplink option
How are you handing out the IP addresses ?
I am wondering if your PC IP address when you connect directly might be having an IP conflict with the other devices ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Nope, I statically set all the IPs, No change.
Any other ideas are welcome. I'll try anything.
What happens if you connect the printer directly to e1 and bypass the switch ?
I think you need to reconfigure the port configuration for e1 .
Thank you
Victor Fabian
Since the port configuration has been set as a trunk using the native VLAN 1 and that VLAN is not defined in the IAP , there's no way for the printer to reach the 192.168.1.x network with that setup.
One thing you can do is to upgrade to 6.2.1.0-3.3 and it allows you to define hows the device is connected to that port will get it's IP address (Virtual controller assigned or Network assigned) and this option is not available today on the other code.
Hope this helps
Thank you
Victor Fabian
