Frequent Contributor I
Troubleshooting AP upstream connectivity issue
I'm having what appears to be some connectivity issues with some of my APs between them and the controller.  I could have sworn at one point I came across a cheat sheet for troubleshooting these kinds of issues, but I can't find it now.  Does anyone have a good set of commands they'd be willing to share?
(As background, it appears to be only happenning on APs connected through Juniper EX4300 switches, so I want to gather up more data before I decide which vendor to start a support case with.)
Re: Troubleshooting AP upstream connectivity issue
No cheat sheet, but what I do with our APs on Juniper EX3300 switches:
1) monitor aruba syslogs for APs that are down, reboot, or bootstrap, to identify specific APs
2) on the local controller supporting a suspect AP,  on the GUI look under Diagnostics -> Access Point -> System Status -> <ap_name> , or on CLI:
show ap debug system-status ap-name "<ap_name>", and look at bootstrap data and missed heartbeats, CPU and Memory Usage,
Interface counters/information, etc.
3) On the switch servicing the AP, check the interface extended stats:
sw-ex3300-1> show interfaces extensive ge-2/0/40
Look for Input errors; Output errors; Queue Dropped packets, Autonegotiation Link partner values, MAC stats, etc. for any anomalies.
Depending on what I find and where, I'll look for common issues and start the conversation with our wire techs, Juniper TAC, or Aruba TAC.
Mike Davis
Network Engineer
University of Delaware
Thanks, that's at least a start!
