Trunk VLAN Trusting best practices?
What would be the best practices when considering trusting vlans on a trunk port?
My uplink to the router is a trunk. I have the option to trust vlans. I trust this link because it is my router directly connected.
Why would I want to individually trust vlans as opposed to trusting all vlans?
Or put another way, why would I want to untrust vlans?
Re: Trunk VLAN Trusting best practices?
By default, all VLANs on a trunk are trusted.  You would "untrust" a VLAN on a trunk if you wanted wired users only on that wired VLAN to get a captive portal when that wired  user traffic is coming into the controller, for example.  99% of the time it would be the default, which is trusted and passing traffic
