Occasional Contributor I
Trusted or not trusted
On my controllers I have a management port and my data port.  I know that the mgnt port needs to be trusted.  Does the data port need to trusted also?
Aruba
Re: Trusted or not trusted
That depends.  If you move to Untrusted, then you are essentially invoking the firewall of the controller and then things like AAA profiles, roles, and policies come into play.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Aruba
The global wired AAA profile controls this behavior by the way.  Keep in mind that the port AND/OR the VLAN can be set to untrusted on the controller.
Seth R. Fiermonti
Email: seth@hpe.com
Aruba
If its the main (only) egress port on the controller, yes you want the port trusted (default) or your user table will fill up with all the wired MACs that can be seen from this port.   e.g. hundreds of entries pretty quickly.
