Occasional Contributor I
Trying to Understand and troubleshoot a wireless mesh
Can someone explain the read out below.  What are the key things you would look for when troubleshooting a mesh link?  All of the links are up.
Thanks for the help
(MIS-ARUBA-MASTER) #show ap mesh neighbors ap-name "Peachtree MS Portal" names
Neighbor list:
MAC Portal Channel Age Hops Cost Relation Flags RSSI Rate Tx/Rx A-Req A-Resp A-Fail HT-Details Cluster ID
Peachtree_MS_TR_2305[c] Peachtree MS Portal[p] 36 0 1 4.00 C 2h:15m:52s - 17 18/12 1 1 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_2807[c] Peachtree MS Portal[p] 36 0 1 4.00 C 23m:19s - 14 18/18 6 6 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_2667[p] Peachtree MS Portal[p] 36 0 2 16.00 N 18h:49m:30s S 10 - 0 0 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_2667[c] 00:00:00:00:00:00 - 23 1 65535 N 18h:49m:44s S 6 - 0 0 0 Unsupported -
Peachtree_MS_TR_2305[p] Peachtree MS Portal[p] 36 0 1 4.00 N 2h:15m:48s - 17 - 0 0 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_1620[p] Peachtree MS Portal[p] 36 0 2 22.00 N 18h:49m:59s S 7 - 0 0 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_1620[c] Peachtree MS Portal[p] - 4 1 41.00 N 11h:16m:41s S 6 - 1 1 0 Unsupported DCSS-aruba-mesh
Peachtree_MS_TR_2807[p] Peachtree MS Portal[p] 36 0 1 4.00 N 13h:47m:52s - 14 - 0 0 0 Unsupported DCSS-aruba-mesh
Total count :8
Relation: P = Parent; C = Child; N = Neighbor; B = Blacklisted-neighbor.
Flags: R = Recovery-mode; S = Sub-threshold link; D = Reselection backoff; F = Auth-failure; H = High Throughput; L = Legacy allowed; a = SAE Accepted; b = SAE Blacklisted-neighbour; e = SAE Enabled
Re: Trying to Understand and troubleshoot a wireless mesh
Please open a support case for this.  It does not look normal.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
