Thank you for your informative response.
We are running a Aruba 315 system with a Virtual Controller (running in a virtual machine).
When I click to enable "Client Match" it enables and I press okay. But when I check to see if the setting sticks it goes back to disabled. Any idea why it's doing this? Is a reboot of some kind required?
Attached is a screenshot of the setting in question.
Thanks.
