I managed to get my 7010 successfully connected to my master 7220 at HQ on port 4094 int. G0/0/15. It's reachable via ssh and WebUI. The global config from the master has been pushed out to the 7010.
Uplink Management Table
Id Uplink Type Properties Priority State Status Reachability
1 Wired vlan 4094 200 Connected * Active * Reachable
Now I want to extend existing client vlans from our HQ controller and connect APs to the 7010. Do I do this by configuring vlans directly on the 7010 or do I use the Smart Config Branch Config Group on the master? Or some of both? Do I need to do any further configuration on the 7010 or is everything now done through the Branch Config Group on the master 7220?
Specifically, I want to:
- Connect APs to the 7010 and push an AP-Group to the AP using existing VAPs from our HQ 7220. Clients should get leases from our centralized campus DHCP server in vlans existing on the HQ 7220.
- Use existing vlans from our HQ 7220 for wired client connections also using our centralized DHCP server for leases.
Not sure if I configure these using the "User Vlans" section (Networking tab) or "DHCP Pool" section (Routing tab) on Smart Config, or do I create the L2 vlans directly on the 7010?
I'm trying to do all of this by only looking at the ArubaOS 6.4.4.x User Guide but am getting lost. Is there a VRD or other guide available?
For testing, I provisioned the branch controller using "mini-setup" mode and it successfully found the HQ master. In production I'll need to use full-setup mode because we are given a static IP from the broadband provider. The full-setup mode parameters are a little confusing and I don't see step by step for full-setup in the UG.
Any help would be appreciated!
Thanks in advance,
Mike
