MVP
Tunnel GRE hub and spoke
It is possible to build a tunnel gre in hub and spoke?
For example
We would like to have a vlan example vlan 999 to pass between all controllers though a hub
Let say i got 3 controllers
I got the vlan 999 that will pass betweent controllers
Copntroler 1 = 192.168.99.1 Spoke1
Controler 2 = 192.168.99.2  HUB
Controller 3 = 192.168.99.3  SPoke2
Now i build my GRE Tunnel from Hub 1 to spoke 1( The tunnel works fine i can pass traffic between them
Now i build my GRE tunnel  from hub to spoke 2 ( ( The tunnel works fine i can pass traffic between them)
Now here is the problem
If i try to ping from spoke 1 to spoke 2 and the packet has to pass trhough the hub i dont reach...
Do i need to add anything to make this work? or its impossible?
The config is something like this :
HUB to spoke 1
interface tunnel 60
        tunnel source 10.10.10.5
        tunnel mode gre 0
        tunnel destination 10.10.20.5
tunnel vlan 999
trusted
no inter-tunnel-flooding
HUB To SPOKE 2
interface tunnel 61
        tunnel mode gre 0
        tunnel destination 10.10.30.5
tunnel vlan 5
trusted
Should i just enable the inter tunnel flooding?  i saw it in a config  looking for a example of configs but it donest not say too much of what is it on the manual anyways
Cheers
Carlos
Alternetworks Corp
MVP
Re: Tunnel GRE hub and spoke
It was the non inter tunnel flooding
I just needed to enable it.
Cheers
Carlos
Alternetworks Corp
