Tunnel establishment between Access point And Aruba controller
Am new to WLAN and also new to ARUBA products.
Topology :
ArubaAccessPoint(CAP) ----> DistributionSwitch -----> ArubaController
                                                        DHCPServer
Initially any tunnel establishment will happen b/w AP and AC immediately After AP associated with AC
Below is scenario :
1. AP is in Campus access mode.
2. AP got ip address from DHCP Server
3. AP upgrade with image and basic configuration from Controller (AP is in "default" group)
4. ?
    (here tunnel will be established b/w AP and AC ? )
Appreciate your prompt response
Re: Tunnel establishment between Access point And Aruba controller
While going through the Aruba documents found , GRE tunnel will be created b/w AP and AC.
Have one more doubt regarding this , is there in exceptional scenario where tunnel won't esablish b/w AP and AC.
No.  It always happens that way, by default.
Thanks Joseph.
Is this true for RAP (Remote Access Point) also in bridge mode ? as in one of the document they have mentioned
"""The bridge-mode SSIDs do not have a GRE tunnel back to the controller"""
RAPs have an ipsec tunnel for management.
Thanks Joseph.
in both cases (GRE and IPSEC tunnel) , is PAPI used for detecting connection's health ?
In a campus ap, papi is used for control and ap state monitoring. Gre is used for tunneling user traffic.
In a remote ap that is done over ipsec.
that means "ipsec tunnel will be established in RAP irrespective of forwarding-modes (Bridge,tunnel,split-tunnel .....) ?.
Am beginer , are there any documents available to get clear idea on different RAP forwarding modes (Bridge,tunnel,split-tunnel .....).
1. Yes. Rap will have an ipsec tunnel regardless of forwarding mode.
The user guide at support.arubanetworks.com and the Aruba Validated Reference guides are a good starting point.
