Tunnel mode GRE number - what exactly is it for?
Hi there,
I posted the below as a REPLY to someone else's thread but I didn't get a response.  Hence, I started a new post for it instead ... thank you.
Consider this as an example:
interface tunnel 88
        description "Tunnel to anchor"
        tunnel mode gre 88
        tunnel source 172.16.32.1
        tunnel destination 192.168.15.210
        trusted
        tunnel vlan 888
My question is: tunnel mode gre <num>   - is this <num> a 16-bit protocol type of the payload packet as per the GRE packet header in RFC 2784 ???
In the example above, I use tunnel mode gre 88, and the config works.   I changed it to some other number, says 14, it also works.
ArubaOS 6.4.4.0 continues to support L2 GRE tunnel type zero, but it is recommended to use a non-zero tunnel type.     So what is the real use of this <num> as in tunnel mode gre <num>?
Kind regards
Kenneth
Re: Tunnel mode GRE number - what exactly is it for?
I believe it allows the controller to differentiate between multiple GRE tunnels. If you have multiple layer 2 GRE tunnels the controller would no layer 3 details (IP & Netmask) to identify the tunnels by...
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
