Tunneling between controller....
Hi all,
I will deploy one new controller(controller B) in DR site for clients (vlan 100)..Now I have a controller(controller A) in my existing production network. And I want the vlan100 gateway is in the existing building. I have a idea that can I form a tunnel between two controllers in order that centralize all remote traffic(vlan 100) back to exsiting network? the tunnel should be layer 2 ,right?
any one can help? or give me some reference/document?
many thanks
Aruba
Re: Tunneling between controller....
Have a look at these articles/posts to get you started.
AMFX | ACCX | ACDX | ACMX
MVP
Here's the config I'm using:
Controller2 (users in the VLAN100 get tunnelled back to Controller 1)
interface vlan 100
	ip address 192.168.0.249 255.255.255.0
interface tunnel 91
	description "Guest Tunnel"
	tunnel source 10.30.1.254
	tunnel mode gre 0
	tunnel destination 10.21.0.65
	trusted
	mtu 1500
	tunnel vlan 100
Controller1 (head end, where layer-3 happens for VLAN100)
interface vlan 100
	ip address 192.168.0.250 255.255.255.0
interface tunnel 91
	description "Boise Guests"
	tunnel source 10.21.0.65
	tunnel mode gre 0
	tunnel destination 10.30.1.254
	tunnel vlan 100
I'm using this for guests, so I trust at the far end, and do-not-trust at the head, and they get dropped off on the portal.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
