Contributor II
UDR VLAN *and* Role?
Offhand, does anyone know if you can use a UDR to both set a VLAN *and* a Role (based on a DHCP fingerprint)?
I know I can set individual rules to do either - would both rules be processed?  Or just the first one in the list?
Kevin Schoenfeld
Re: UDR VLAN *and* Role?
No, and the reason is that only a single change can be returned by a UDR - either a role OR a vlan.  Whatever rule is triggered first is applied and all the others are ignored.
Contributor II
Thanks Colin.  I suspected as much but wasn't in a position to test.
Kevin Schoenfeld
