USB Parameters for K4203
Hi everyone, any know the USB parameters (USB Device Identifier, USB Dial String and USB mode switch) for the following 3G modem: Huawei K4203?
I need them for RAP3 deployment.
Gian
Aruba
Re: USB Parameters for K4203
The Huawei 4203 is not currently supported.   Please visit the following page for supported devices:
http://www.arubanetworks.com/support-services/interoperability/#3GEVDOUSBModemsforRemoteAccessPoints
If your up for it, you could try the parameters for the E3276; but the device is not on the supported list:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/USB-Parameters-Huawei-E3276-RAP-155-ArubaOS-6-4-0-3/m-p/167012#M35494
AMFX | ACCX | ACDX | ACMX
Thanks Clembo for your quickly reply.
In your link I see that the ArubaOS is 6.4... in my scenario the Aruba OS is 6.3.1.1.
I have tried but it doesn't work.
Could the upgrade help me?
Gian
Aruba
I can't say for sure....as I first mentioned, that device is not supported in any version right now by Aruba.  I only suggested the second option as something to try.
