Regular Contributor I
USB modem backhaul - for RAPS only or IAPs too?
I'm trying to determine if USB cellular modem backhaul is only available in RAP models or IAPs as well. I'm looking to offer a standalone AP that would work "in a field" away from ethernet connectivity, so USB modem backhaul is a must. Can someone please confirm?
I found a link that suggests IAPs support USB backhaul but the AP specifications page don't include that info.
http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Instant%20User%20Guide%20-%20volumes/Uplink%20Configuration.htm
Also, can someone confirm if this is the most updated list of compatible "True Auto Detect" USB modems?
Mike
Re: USB modem backhaul - for RAPS only or IAPs too?
Yes you can!
Recommended modem for Verizon is the Novatel U620L
Tim Cappalli | Aruba Security
Booya! Thanks Tim for confirming IAP works with USB backhaul. I actually had the U620L in my sites but it's not listed on the "Uplink Configuration" URL I sent out so needed confirmation.
Mike
