Upgrade AIPs with controller
Hello, I have a Aruba controller (3200) with latest firmware ( with 23 IAPs.
Is it possible to upgrade the IAPs firmware? I try to connect by web, but I can get nothing.
Valued Contributor II
Re: Upgrade AIPs with controller
No. it is not possible to upgrade the firmware of an IAP through a controller coz the Controller image and the IAP ( VC) image are different.
Let me understand something here, why are you using a controller along with IAPs, IAP itself will have controller functionality. please clarify whether you are using IAPs or APs .
If you are using APs, AP always update it's code through the Controller.
Please feel free for any further query on this.
Venu Puduchery,
OK. Sorry for the confusion.
I have controller with APs, so I don't need to upgrade.
Kind regards.
