Super Contributor I
Upgrade Firmware
Hi, i have one question.
ARUBA SOFTWARE allows updating the AP automatically when the controller is updated?
Thanks.
Re: Upgrade Firmware
Yes, the AP is upgraded during the boot process.
Tim Cappalli | Aruba Security
Super Contributor I
Ok, There is some documentation about it?
There's not a whole lot of documentation, it's an automated part of the AP
boot process. There is a new feature in 6.3 called AP image pre-load. You
can read about it in the 6.3 user manual.
