Frequent Contributor II
Upgrade after advisory problems 802.1x
Hi I have upgraded 2 x 6000 controllers to 5.0.4.13 after the certificate advisory. All ok apart from one user role uing 802.1x with temination on the controller. XP and win 7 laptops not authenticating, tried unchecking use server certificate and some work most dont. Any ideas ?? All other devices, tabs/mobiles work fine.
ACMA/ACMP
Re: Upgrade after advisory problems 802.1x
If you delete the wireless profile from the client, is it able to connect
after entering credentials again?
Tim Cappalli | Aruba Security
Hi, not in most cases, I have used my laptop (win 7), not on their domain, and a user from the company can log in and authenticate no problem. However this is with use server cert unchecked, I dont know if it is an issue with the self signed cert or a user profile problem.
The 802.1x profile in question is using local termination, if I uncheck this and save it and then go back it is checked again.
ACMA/ACMP
Hello did you check that it really changed the certificate?
In some controllers this didnt work.. for example on A200 it didnt work... on 5.0.4.14 was the fix...
Check please if it changed the certificate sucessuflly
You can read how you check that here
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Support-Advisory-ArubaOS-Default-Certificate-Expiration-11-21/td-p/116511
And also you can read that the 5.0.4.13 didnt fix on for example a A200
Cheers
Carlos
Alternetworks Corp
Can you please enable the user-debug and paste show auttrace-buf mac <mac address of the client> output.
To enable user-debug
logging level debugging user-debug <mac address of the client>
Regular Contributor I
hi stunshot,
is it M3 in the chassis?
By the way, did the issue get resolved.
Spoiler
@Cappalli,
is it happening on the windows7 stations because the CA that issued the certificate has changed?
if the CA thats issuing the certificate is the same, that is iff its my trusted internal CA issues the certificates. So, the each time the certificate expire, i can keep renewing the certificate. and that would be transparent for the clients, correct?
