Upgrade firmware : Please clean flash and try again.
This thread has been viewed 19 times
  • 1.  Upgrade firmware : Please clean flash and try again.
    Posted Jun 23, 2014 04:14 AM
    Help me pls.
    I can do a default flash space?
     I test clean command
     - tar clean flash
     - tar clean log
      -tar cleacn crash
  • 2.  RE: Upgrade firmware : Please clean flash and try again.
    Posted Jun 23, 2014 06:44 AM
    delete any unecessary files, and save to external server the important ones like flashbackup.tar.gz
    delete filename <name>
     Once you have the required 70 MB available, try the upgrade again.
  • 3.  RE: Upgrade firmware : Please clean flash and try again.
    Posted Jun 24, 2014 10:35 AM
    Michael,
    I am having the same problem with upgrading an A620 controller.  I get an error that says I need 60MB for the upgrade.  When I show storage, I see that I only have 51MB in flash.
    (Aruba620) # show stor
    Filesystem                Size      Used Available Use% Mounted on
    /dev/mtdblock11         156.0M    105.0M     51.0M  67% /flash
    none                    300.0M      1.8M    298.2M   1% /tmp
    /dev/mtdblock9           50.0M     24.6M     25.4M  49% /mnt/img0
    /dev/mtdblock10          50.0M     24.7M     25.3M  49% /mnt/img1
    When I look at the flash directory contents, it looks like I only have about 27KB of file storage in flash.
    (Aruba620) #dir
    -rw-r--r--    1 root     root        17666 Jun 24 15:32 default.cfg
    drwxr-xr-x    3 root     root            0 Jun 26  2013 fieldCerts
    -rw-r--r--    1 root     root         9426 Jun 26  2013 original.cfg
    drwx------    2 root     root            0 Jun 26  2013 tpm
    I can't figure out what composes the 51MB, or how to free up the neccessary 60MB in order to complete the upgrade.  I have tried performing the upgrade through the GUI and the CLI, but get no love either way.  Any suggestions, or recommedations would be greatly apprciated.
  • 4.  RE: Upgrade firmware : Please clean flash and try again.
    Posted Jun 24, 2014 11:00 AM
    cnidog,
    You would have to contact TAC.  Sometimes there are hidden files that only they can delete...
  • 5.  RE: Upgrade firmware : Please clean flash and try again.
    Posted Jun 24, 2014 11:20 AM
    Thank you, Colin.  That is the least best option.
  • 6.  RE: Upgrade firmware : Please clean flash and try again.
    Posted Jun 24, 2014 12:27 PM
    It is also probably the only option, at this point.
