Upgrade issues from 7.6.1 to 7.7.1
I tried upgrading two of my Airwave servers one worked well but the other one gave me this error :
[root@amp-g1 mercury]# start_amp_upgrade -v 7.7.1
Directory not specified; using /root.
Upgrade script found in local cache.
Upgrade package found in local cache.
Checking for any patches or modifications to the code
This process may take a few minutes...
No outstanding changes were found. Continuing with the upgrade.
Validating the upgrade package...
Upgrade package is OK.
Upgrading AMP to version 7.7.1 from version 7.7.1...
Detailed log will be written to /var/log/upgrade/AMP-7.7.1-upgrade.log
STEP 1: Moving old version aside.
STEP 2: Unpacking upgrade package.
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
STEP 3: Checking for compatibility.
STEP 4: Stopping AMP services.
STEP 5: Installing upgrade.
chdir: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
Upgrade aborted.
Please contact Aruba Networks Support at
1-800-WiFi-LAN or support@arubanetworks.com
DISABLED - 4!!
I already open a TAC case but maybe somebody here has seen this before .
Thanks in advance
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Moderator
Re: Upgrade issues from 7.6.1 to 7.7.1
Is your CLI session getting stale?  Try to refresh current directory:
# cd /tmp
# cd /root/svn/mercury
(don't really need cd /tmp, but that's just precaution to make sure you exit current directory before returning to it)
Then try the start_amp_upgrade command again.
The reason this might work is because during the upgrade, the /root/svn/mercury directory is moved to mercury_old, while a new mercury folder is being built.  At failure, the AMP tries to back out by removing the new mercury and putting mercury_old back into the mercury directory.
If this doesn't work, please open a support case to track.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
