Super Contributor II
Upgrade of 6000 controller to 6.1.3.8
    I am trying to upgrade a 6000 series with a single M3 from AOS 6.1.3.1 to 6.1.3.8 using the GUI but it is showing an error something like "not supported on this platform". the file I am trying to upload is - ArubaOS_MMC_6.1.3.8_38170.
Any reason why this might not be working?
Re: Upgrade of 6000 controller to 6.1.3.8
A. Try to download the image file agian - it might be broken file
B. Before upgrading clear old unneeded files/backups from the controller
C. Try to upgrade using TFTP
This was overcome by placing the file closer to the device rather than across a VPN. Not sure the exact cause of failure but managed to work around the issue.
Contributor II
Any issues after the upgrade?
