Regular Contributor II
Upgrade to 6.3.1.17 syslog being battered with warnings
Just upgraded 2 7220's (master/local) to 6.3.1.17 from 6.3.1.2 and our syslog server is being literally battered with the following warnings:
 asap_firewall_forward: bond0, insufficient headroom, require 66, but 64, skb data length 46.
Prob about 700mb syslog messages for the 2 controllers.
Things "seem" to be "ok"... but when we typically see about 4mb of log files per day.. something aint right!
The upgrade was somewhat forced, after I was planning to schedule it in this week, and preloaded the images to the non boot partition, and the local rebooted this morning.. for some reason, and booted into the new partition, causing an upgrade to all connected APs.  So I had to upgrade the Master this evening.
Any ideas what these warnings are about??
Re: Upgrade to 6.3.1.17 syslog being battered with warnings
For now, it seems to be cosmetic.  It was introduced in 6.3.1.17.  We will post here when we see what version of code the fix will be put in.
Thanks.. Ill see what I can do to supress these messages so we can actually see stuff from the 500 other devices we monitor!
Id it possible to just turn off this specific trap, as Ive had to re-enable higher level of syslog due to some issues we are having, and this error produced about 16gb of log files in less than a week!
This is targeted to be fixed in 6.3.1.19.  Unfortunately, you cannot stop syslog for specific messages.
...you mean whatever they turned on in .17, theyre turning back off again?!
Thanks again for the clarification
The condition that is causing that specific message is being fixed so that it no longer generates that message.
got that too on AP125 connected to MC3400 under 6.3.1.18 , i suddenly saw this today in CLI log on the AP125 itself.
anyways.. thanks for fixing this soon in 6.3.1.19
regards
ben
Occasional Contributor I
6.3.1.19 release?
Moderator
networkforce@systex.com.tw wrote:
6.3.1.19 release?
It is currently expected to be around 14th November, but this is subject to change without notice.
