Upgrade won't work
  • 1.  Upgrade won't work
    Posted Mar 09, 2017 10:58 AM
    I try to upgrade to 8.2.3.1 - but won't work.
    I even downloaded to /root on the server to upgrade...
    But command say something that file was not found in local cache.. see screenshot
  • 2.  RE: Upgrade won't work
    Posted Mar 09, 2017 11:08 AM
    I had to run the following command as stated in the error message:
    fix_missing_indices
  • 3.  RE: Upgrade won't work
    Posted Mar 09, 2017 11:31 AM
    Hi Christiaan,
    As Vincent suggested please run the command fix_missing_indices before we start the upgrade. Looks like the server needs a database schema check prior to upgrade. Sometime it will prompt you for the same check after the upgrade as well.
  • 4.  RE: Upgrade won't work
    Posted Sep 20, 2017 08:10 PM
    I'm trying to upgrade from 8.2.4 to 8.2.4.1, and I get that same error message :
    "Upgrade aborted!
    Run fix_missing_indices to fix the missing indices!"
    Since there's no more CLI in 8.2.4, how can I run "fix_missing_indices"?
  • 5.  RE: Upgrade won't work
    Posted Sep 20, 2017 09:05 PM
    Please open a TAC case. They should be able to help you out with this.
