Upgraded my Controller to 6.4.2.2 and am now recieving constant error
Upgraded our 3600 to the OS 6.4.2 and am now recieving this error constantly. Is there something that I need to turn off?
<319001> <ERRS> <ab3600 10.2.63.246>  Unexpected (arm process) runtime error at arm_update_sta_arm_cm_stats_section_moves, 625, Fail to update arm_cm_stats section loadbal_moves field for sta f8:27:93:a3:60:94, Error = 43, error_htbl_key_not_found
Re: Upgraded my Controller to 6.4.2.2 and am now recieving constant error
This is cosmetic and should be addressed in the upcoming 6.4.2.3 release.
Upgraded our controller envoironment from 6.3.8 to 6.4.2.3 and am getting this error also...Only on the 6000-M3 and 3600 controllers....go figure.
Dec 18 09:41:11 :319001:  <ERRS> |ARM Process|  Unexpected (arm process) runtime error at dot11v_btm_req_cb, 75, Unable to find STA d4:f4:6f:75:55:6d
Dec 18 09:49:17 :319001:  <ERRS> |ARM Process|  Unexpected (arm process) runtime error at dot11v_btm_req_cb, 75, Unable to find STA d8:bb:2c:18:81:d4
Everything else is running ok, even our Clearpass...
Moderator
Hi ronsmith35,
Can you open a tac case on it (just tar logs techsupport would suffice), or, you can email me your techsupport logs and I will open a bug on it (email is my forum username here @ aruba)
regards
-jeff
I opened a case with TAC.  Looks to be a bogus ARM error...but they will get back to me.
this release was removed from the support website , you should upgrade to the 6.4.2.3 version , this version got some problem.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
