Occasional Contributor I
Upgrading a 7200 Cluster Firmware
Hi Everyone,
I have a cluster of two 7200 controllers ina active/passive currently running 6.4.3.9.
what is the best way to upgrade
1. install firmware on master and reboot
2. install Firmware in local reboot
and second q. is going from 6.4.3.9 to 6.5.0.3 ok
is there a upgrade matrix i.e before going to 6.5.x.x you must be on 6.4.x.x
Re: Upgrading a 7200 Cluster Firmware
You can upgrade to/from those firmwares with no issue.
Upload the file to both and then reboot at the same time.  Make sure you do a "backup flash" on both controllers before you reboot, just in case you have to revert...
Colin Joseph
Aruba Customer Engineering
New Member
I think it would loss connectivity if rebooting both controller at the same time, right?
#AirheadsMobile
Yes.  You need an upgrade Window.
Colin Joseph
