Regular Contributor I
Upgrading an old RAP to work on 6.3
I have an old RAP-2WG running 5.0.0.0.
Of course it doesn't want to come up on my controller running 6.3.
Does anyone have a flashing procedure? I found some info suggesting I need a controller running 5.0.0.4 but unfortunately that's not an option for me.
regards
B
ACMA ACMP
Re: Upgrading an old RAP to work on 6.3
The easiest way to do it would be to open a TAC case. They can point it at controller(s) to do the step upgrade.
Tim Cappalli | Aruba Security
