Uplink Load Balancing
Hi all,
i have never tray the Load Balancing feature in Aruba Controllers, have any one tray it before.
can any one help me to deal with that
i want that 2 ssid take the first connection and the 3ed ssid take the 2end connection
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Uplink Load Balancing
Where are you seeing this?
Tim
Tim Cappalli | Aruba Security
hi ,
a have seen it in  version 6.3 and bellow in (Network>uplink>uplink Manager), it is not supported in version 6.4
Raouf CHAHBOUNE
