[Urgent] APs 105 not working with Etherent port 10 mb
dear all,
i found  some truble when using old cisco catalyst switch 1900 serie with Aruba AP 105 , we can't detect the AP from the controlleur.
I susspect the switch speed 10 MB ,
any suggestion ?
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: [Urgent] APs 105 not working with Etherent port 10 mb
as already mentioned the problem is in the port speed on the datasheet they clearly say that the AP 105 work with the switch 100/1000 BASE-T
Raouf CHAHBOUNE
Super Contributor I
Might also want to check the power if this is a Poe switch. You'll need 802.3af.
ACDX #419 | ACMP |
Super Contributor I
Now that I read the spec sheet rchahboune is most definitely correct. If you're not using both 10/100 ports you could try using one of those, but other than that I would honestly invest in some newer switch hardware.
ACDX #419 | ACMP |
