Frequent Contributor I
Use VLAN name for split-tunnel vap
Fellow Airheads,
I am trying to clean up my RAP configs and currently I have a separate ap-group for each one of ten VLANs. I would like to create a VLAN pool to simplify things down to one ap-group and use a VLAN name so I can re-use configs on multiple local controllers.
I know that the VLAN name even assignment is limited to tunnel and decrypt-tunnel modes. However, can I still use the hash algorithm and assign a VLAN name to a pool to be used in a split tunnel VAP or wired port profile?
Thanks!
Re: Use VLAN name for split-tunnel vap
VLAN pool or Name VLAN are not supported in Split-tunnel mode
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Ok thanks!
