Use other port than 443 for connecting RAP and VIA clients?
we currently run a test-environment of Aruba. On our site we already have an VPN-solution to connect remote clients. Therefore port 443 of our static Internet IP will be forwarded to the VPN-router.
Now, we also want to test Aruba VPNs but can't do because they need 443 either. Is there a way to tell VIA and/or RAP3 to use any other port than 443 (maybe 80, which is currently not used, or any other port). I know that this may not work in foreign environment of hotels or such, but this is not a problem for now.
Re: Use other port than 443 for connecting RAP and VIA clients?
At this time, it cannot be changed, unfortunately.
As colin said, you can't change this. But only VIA requires 443. RAPs do not use 443, they only require UDP 4500.
Sathya
