Users connected in 2.4ghz band are getting low signal Strength and health becomes low.
when a clients connected to 2.4ghz bandwith they are getting low signal strengh and the application access become vey low, when i entered into aruba 7010 controller the user health is showing as 4%.
Contributor II
Re: Users connected in 2.4ghz band are getting low signal Strength and health becomes low.
you might find that you have some wireless coverage holes, which is why the user would be getting poor coverage.  A wireless survey would iluminate any coverage issues.
thank you,
ACMP CWDP
Frequent Contributor I
Make sure the client close to AP.
Thank you,
Ratchapas S.
