Occasional Contributor I
Using AP 205 without controller
My idea is as below . pls tell me this is a possible or not.
Phase 1 : *2 AP 205 wihtout controller
Phase 2 : add *10 AP-205 and controller
thanks in advance
Re: Using AP 205 without controller
You cannot use the AP-205 without a controller. You would need to purchase IAP-205s. They could then be later converted to a controller-based AP.
Tim Cappalli | Aruba Security
You will need to wai that aruba start selling the Instant 205, which they havent yet...
Cheers
Carlos
Alternetworks Corp
