Using AP-205s with IPSec
Any guidance on how to configure AP-205s to use IPSec with certificate authentication? When I provision the AP-205 through the GUI (Aruba OS 6.4.2.2) there is no option available to set the AP as a Remote AP.
Are the AP-205s capable of being set up as Remote AP with Remote AP Authentication set as Certificate?
Aruba
Re: Using AP-205s with IPSec
The AP-205 can operate as  RAP; and does has a TPM module for cert-based authentication support.    Can you send a screenshot of the provisioning page of an AP-205?  It should have an Authentication Method section; which includes Remote AP options.
AMFX | ACCX | ACDX | ACMX
Please find attached a screen shot of the provisioning page for an AP-205.
Aruba
Can you try a different browser or even a different machine?   The format of that page does not look correct, for example the section under AP Installation Mode typically is under the Authentication section.
It was the browser.  I was using firefox and tried it with Chome and the GUI provisioning page looks correct. Thanks for your help.
