Using AP-ANT-38 with a AP-134
  • 1.  Using AP-ANT-38 with a AP-134
    Posted Jan 14, 2015 04:42 PM
    I'm setting these up to create a backhaul from a remote building to the main buildings portal.
    I have a couple questions
    1) I have 3 antenna wires labled -45, 90 or V, and +45. On the AP-134, the ports are labled ANT0, ANT1, and ANT2. I couldn't find documentation that stated which should be matched up so I connected them in order as if they were mounted on a wall. It's in the attached picture. So that -45 goes to ANT0, 90 goes to ANT1, AND +45 goes to ANT2. Is this the correct way to connect them?
    2) I want to understand the polarization V, and Slant +/-45 deg. better but can't find a document that explaines clearly. Can you point me in the right direction?
    Thank you
  • 2.  RE: Using AP-ANT-38 with a AP-134
    Posted Jan 15, 2015 01:37 PM
    I beleive this shouldn't matter. They way you have the cables connected now are fine
  • 3.  RE: Using AP-ANT-38 with a AP-134
    Posted Jan 15, 2015 01:59 PM
    Would you have any ideas on the second question?
    Thanks!!
