Frequent Contributor II
Using Aruba as edge firewall
In a small office we have a 650 we want to use as the edge firewall, in addition to its role as wireless controller.  Is there a preset AAA profile that should be applied to the untrusted uplink interface to protect it from all the evils of the internet? Or will there only be a need for a AAA policy if there is incoming traffic needs such as web server etc..
MVP
Re: Using Aruba as edge firewall
[ Edited ]
(MAKE SURE YOU HAVE PEF/PEFNG INSTALLED)
Yes, you can apply firewall policies to the network interfaces (physical or VLAN). You can do this on the GUI at Configuration/Netowrk/Ports menu.
Create your firewall policies first and simply apply it to the interface and it should do the job.
**IF U JUST WANT TO ENABLE FIREWALL ON PORT/VLAN  - JUST ADD ACL PROFILE to your VLAN/PORT**
 You can if you are using different vlans for each tunnel. You can apply the aaa profile right on the vlan itself.
Thanks kdisc98,
I was wondering specifically if there is a firewall policy that is kind of the default policy for this type of usage.  I did not see any firewall policy like default-inbound-firewall. Is there something I should put specifically on this that covers the most common use cases?  I just don't want to reinvent the wheel with creating this policy if one is already in circulation.
thanks
Matt
MVP
  • It's depands which services you would like to block.
  • build/config/coustimze your own.
So there is no good starting point for this, It is just from scratch.  Do I need to explicitly deny all incoming traffic or does the Untrusted port do that by default?
MVP
[ Edited ]
  • just add firewall policy to your WAN port - and leave it trusted.
  • Untrusted ports - usully used to auth wired users,untrusted port will do it by default. (BLOCK EVERYTHING - ALL KIND OF TRAFFIC EXCEPT WHAT YOU WILL ALLOW IN THE ACCESS ROLE THAT )
