Using Mesh Configuration
Where do i start if i want to config the backbone for one of my AP-135 get from another AP-135 (same like wds or mesh?)
Re: Using Mesh Configuration
In the ArubaOS user guide, there is a chapter called secure enterprise mesh.  The user guide is here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=5926
Colin Joseph
Aruba Customer Engineering
thank you joseph i'll read it first
