Occasional Contributor I
Using Option 43/60 for ZTP with Aruba IAP and isc-dhcpd
Hi Everyone,
I'm trying to get a isc-dhcpd to send the correct option43 and option 60 against a Aruba IAP however for some reason everything on the console get corrupted on the IAP when it get the messages from the DHCP and it does not get the full message. Does anyone have a working config for the IAP and with isc-dhcpd?
My config is below and i've tried both text and string in the code.
option space ArubaInstantAP;
option ArubaInstantAP.InstantAP60 code 60 = { string };
option ArubaInstantAP.InstantAP43 code 43 = { string };
option ArubaInstantAP.InstantAP42 code 42 = { string };
option local-encapsulation code 43 = encapsulate ArubaInstantAP;
option ArubaInstantAP.InstantAP43 "<Folder>,<Airwave-IP>,<Airwave-psk>";
option ArubaInstantAP.InstantAP60 "ArubaInstantAP";
option ArubaInstantAP.InstantAP42 "0.se.pool.ntp.org";
Thanks in advance
/Rickard
Re: Using Option 43/60 for ZTP with Aruba IAP and isc-dhcpd
I have never deployed using isc-dhcp.  Do you have the console output?
Below is the console output for a successful Option43/60 deployment:
GOOD DHCP
v0.9.9-pre) started
Jan  1 00:00:31 udhcpc[2976]: send_discover: pkt num 0, secs 0
Jan  1 00:00:31 udhcpc[2976]: Sending discover...
[   43.151015] Kernel watchdog refresh ended on core 1.
Jan  1 00:00:33 udhcpc[2976]: send_discover: pkt num 1, secs 512
Jan  1 00:00:33 udhcpc[2976]: Sending discover...
Jan  1 00:00:35 udhcpc[2976]: send_discover: pkt num 2, secs 1024
Jan  1 00:00:35 udhcpc[2976]: Sending discover...
Jan  1 00:00:37 udhcpc[2976]: No lease, forking to background.
Jan  1 00:00:57 udhcpc[3165]: send_discover: pkt num 0, secs 6656
Jan  1 00:00:57 udhcpc[3165]: Sending discover...
Jan  1 00:00:58 udhcpc[3165]: send_selecting: pkt num 0, secs 6912
Jan  1 00:00:58 udhcpc[3165]: Sending select for 10.220.85.147...
Jan  1 00:00:58 udhcpc[3165]: Lease of 10.220.85.147 obtained, lease time 259200
Jan  1 00:00:58 udhcpc[3165]: DHCP OPT 60 is not ArubaAP
Jan  1 00:00:58 udhcpc[3165]: DHCP OPT 60 is ArubaInstantAP
Jan  1 00:00:58 udhcpc[3165]: DHCP OPT 43, len: 43, buf: STORES:US:NY:8821,192.168.12.23,Aruba2example!
Jan  1 00:00:58 udhcpc[3165]: ams-ip: 192.168.22.23, length of ams-key: 11
Jan  1 00:00:58 udhcpc[3165]: DHCP OPT 42, len: 8, ip: 192.168.2.16
[   70.059012] ip_time_handler: Got ip and packets on bond0 Started master election 35-0, rand 31
[   79.423992] bonding: bond0: releasing backup interface eth1
[   79.478381] ethernet_device_event: dev eth1 others: 9
[   79.539550] ethernet_device_event: dev eth1 is down
[   79.597063] ethernet_device_event: dev eth1 others: 8
[   79.660543] ethernet_device_event: dev eth1 others: 13
[   79.719150] ADDRCONF(NETDEV_UP): eth1: link is not ready
[   79.782411] ethernet_device_event: dev eth1 is up
10.220.85.147 255.255.255.0 10.220.85.254
Compressing all files in the /etc/httpd directory...
Have you seen the Instant Validated Reference Design guide chapter "Aruba Instant management using Aruba AirWave"?
The console output gets corrupted when the device gets all of the option43 message and when you run "show dhcpc-options" it does not show the correct thing.
Do you have an examplenconfig from when you did it?
I don't have screenshots of the windows server I used.  I used the example from the Instant Validated Reference Design document.  Do you know what version of Instant you are using?
Yes I used the design document, however ai think it's something with my linux dhcp-server (isc-dhcpd) and the lenght of the message in option 43.
I'll update with the version later
The version is 6.4.2.6-4.1.13, is there any bug in this release?
