Does anyone know if it is possible with the AP225/224 to set both the radios to 5ghz? I understand that for this to work well you would need to use extrenal attennas place far enough apart. Another wireless vendor is saying that they could do it and I am just looking to see if Aruba can. Thanks!
This is not currently possible.
No. Aruba APs doesn't support this, we can not configure both radios with the same band ( 2.5 GHz or 5 GHz) .
You should select separate bands for each radio.
