Frequent Contributor II
Using the web UI for packet capture from a client?
I have an issue with a client who is trying to reach an internal resource on a specific device.  It is in a remote branch office and I am unable to stop by to look over the problem in person.  Earlier this morning I read that Aruba controllers have the ability to perform a packet capture from the web UI.
I found the client ip address in the Monitoring -> Clients section of the web UI, and clicked Packet Capture.
On the next screen I see several options to either Refresh, Stop, Delete, Pause, Resume, New, New Raw Packet Capture, or Launch WildPakets.  At this step I do not know how to proceed.  I have clicked the New button and nothing happens.  My guess is that a new capture should start and be listed in the table where I see "None Found".
How do I start a packet capture?
Thank you for any advice!
rwin = 0
Re: Using the web UI for packet capture from a client?
It is more straightforward on the commandline.  Please see the article here;  http://community.arubanetworks.com/t5/Community-Matters-Blog/ArubaOS-6-3-New-Packet-Capture-Functionality-in-ArubaOS-6-3/ba-p/113967
The GUI for the packet capture function has certainly not kept up with the function itself....
Colin Joseph
Aruba Customer Engineering
