Contributor I
VC DHCP and Static VLAN Assignment at the Same Time?
Is this possible?  Can we assign a client to a VLAN and have the virtual controller (VC) provide DHCP for this?
If not:
  • Can the VC be configured to forward DHCP requests to another DHCP server?
  • If the VC does DHCP, can we configure which IP the VC uses to NAT the traffic?
Retired Employee
Re: VC DHCP and Static VLAN Assignment at the Same Time?
Daniel,
I would suggest contacting your SE to participate in the 3.1 beta for Instant. Version 3.1 has the features that you are looking for.
HT
Contributor I
Thanks for the prompt reply.  We did not purchase these directly from Aruba—we purchased them from a third-party—so how may we go about getting the beta software (and, I assume, beta documentation)?
