Trusted Contributor I
VHT Not Operational - Sanity Check
I enabled VHT on a set of AP-225s using AP specific configs, yet my 11ac clients are associated a-HT mode.  I verified that VHT is checked in the radio profile and in the HT SSID profile.  Here are the outputs to confirm the radio is running int VHT:
(controller) #show ap active | include AP01
AP01 XXXXXX X.X.X.190 0 AP:HT:6/12/21 8 AP:VHT:165/15/22 225 A2da 64d:11h:19m:50s N/A
(controller) #show ap bss-table | include AP01
6c:f3:7f:XX:XX:XX TEST-SSID N/A X.X.X.190 a-VHT ap 165/15/22 8 AP01 0 23d:6h:49m:24s 1500 - 2 T
I also did a packet captured and verified that the VHT field is not being advertised in the beacons.
I need a sanity check... what am I missing?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: VHT Not Operational - Sanity Check
I would try disconnecting a client and letting it attach back.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
This has been over the course of a few days, so clients have disconnected/reconnected multiple times.  The fact that the VHT field is not being advertised in the beacons tells me VHT mode is not actually enabled.
When you do a show ap association, for the clients under test, what do you see?\
http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/ArubaOS-6-3-and-Above-802-11ac-Enable-VHT-even-if-you-are/ta-p/145689
Might have TAC take a look at firmware, config, and pcap to see why the VHT isn't advertising in the beacons.
Jerrod Howard
What version of ArubaOS is this? There is a bug where that could happen.
Moderator
Jay
is your AP deliberately being forced to ch165 for some reason (or has arm spazzed out) ? that is not part of the 80 Mhz plan, which is 149-161.. check for rogue ap-name and rf dot11a profile
regards
-jeff
Jeff,
Yes, I added 165 to the regulatory domain. We're using 20mhz channels.
I did have other APs on different channels not running in VHT.
Colin,
I can open a TAC case if you believe it's a bug.
Moderator
ahhh.. duh.... my miswording - can you try changing it out of 165 ? the point I was more thinking (but not saying) was that 165 is not commonly used where "defaults and VHT are used" and it might be a glitch for non 40/80 mhz channel.
but, having said that, just to try it - forced 165 + ap205 + 7260 works ok (6.4.3)
ap205  ac:a3:1e:b7:df:30  5c:c5:d4:7c:a3:44  y     y      1    250    v1-7030-psk  1        0x1001b    a-VHT-20sgi-2ss  10s          1          WAB    0/0
strange one, if it starts working on channel change it will definitely be useful info for a ticket.
regards
-jeff
Colin,
6.4.2.8
Jeff,
Now this is interesting... I have two SSIDs on 5GHz.  One is advertising VHT in beacons, the other is not.  Both share the same HT SSID w/ VHT enabled.  I checked the AP on channel 165 and the VHT field is there for the 'secondary' SSID.
This seems like a bug to me.
TAC case open.  Sanity check cleared. :)  The engineer is trying to reproduce the issue in his lab.
